MOSFET capacitances - which ones matter most?
diarmuid
Full Member level 2
Full Member level 2
Dublin, Ireland
Hello,
I am looking for infomation about the more dominant parasitic caps in a MOSFET.
Would I be correct in saying the most dominant parasitic caps are the following:
Cgs
Cgd
Csb
Cdb
If so,
1.) Is Cgs >> Cgd? I got the below equations from a previous post. Are they correct? If so
I guess that would explain it!
CGD(total)=Cox∙W∙LD
CGS(total)=(2/3) Cox∙W∙ L +Cox∙W∙LD
2.) Is Csb >> Cdb or vice versa? I have no idea about this one!
3.) Are there any other parasitic caps I should also be considering?
Thanks,
Diarmuid
Cgs is usually the one most talked about, and needing to be designed around.
But it depends on what/ where/ how you are using this mosfet.
Cgs is not parastic , it is alsmost real capacitance and is the one that matters the most .
This depends somewhat on the close-in circuit topology.
A low current common-source amplifier will see Cgd as
its bandwidth limiter, Miller gain is the problem especially
when the gate is driven by some weak current source.
A common-drain buffer stage would see Cgd as a less
significant penalty.
