Register Log in
MOSCAP as decoupling capacitor
angyp
Newbie level 5
if i were to use MOSCAP as an on-chip decoupling capacitor , will it affects other nearby devices if it is too big? what is the good way to isolate it.
goodboy_pl
Full Member level 5
the best way is to split the MOSCAP in parallel them to have lower series resistance and more ideal ground connection, also for substrate noise reduction guard ring are used which are NWELL and P+ connection around your MOSCAP or other noisy/sensitive blocks.
BET!
tryagain
Newbie level 1
It is not best ways,this cap will be effected by input voltage and others.
Sunrising
Newbie level 6
Tryagain, would you pls advice what's the best ways?
We use common GND and power supply pins for analog and digital blocks, but the power lines are seperated from pads to various blocks. As for the decoupling capacitors, shall we connect them between the power supply and ground lines for the same block or any power lines is OK?
SC3K01
Newbie level 5
When I applied MOSCAP as the on-chip decoupling capacitors, I found that the leakage of those decoupling capacitor is an issue.
The leakages result from subthreshold one and gate tunneling one. Is it a feasible approach to apply reverse-biased junction diodes as the on-chip decoupling capacitors?
xinsu
Member level 3
we had use reverse-biased junction diodes for ESD protection on chip.
legend
Junior Member level 1
hi,xinsu,
How to use reverse-biased junction diodes for ESD protection on chip? can you explain it more?
xinsu
Member level 3
hi,legend
Add reverse-baised diode arry between different power supply pads,usually connect their grounds.
eric1341
Newbie level 3
What value of diode junction capa? How many area is needed for diode junction capa and MOSCAP if use same value of decoupling capa?
selvaraja
Full Member level 4
hai ang ,
You can avoid using decoupling capacitor if space a constraint by stacking power rails on top of each other. Yau can alternate power and ground rails like interwinning fingers, that depends on metal availables in your process. This technique builds in decoupling capacistors across the power rails for f.o.c .
rgrds,
selva
omsi
Member level 5
London
surround the moscaps byguardring.
make mos caps as big as possible
davidwong
Member level 4
Hi SC3K01,
I would like to know how much is the leakage?
by the simulation the leakage of the MOSCAP is 1e-18 range.
Note : I use 0.5um CMOS process
l.sant
As leakage is your concern I suppose you're using "thin-oxide" devices in a recent technology (130nm or less).. I would not recommend the use of those devices not only because of leakage but also to avoid any robustness and high volume yield issues cause by defects in the oxide or ESD zaps.. In older technologies I've never had a problem using MOS devices as decoupling caps..
Ciao,
LucaS.
