MOS device length in signal path
kenambo
Full Member level 6
Full Member level 6
India
Hi all,
why it is necessary to reduce the MOS length when it comes to signal path?
What are the advantage of reduced length devices in signal path.
example.. a simple differential receiver or a signal comparator..
the size of the receiveing differential pair MOS length is minimised and the width is maximised..
is there any paritcular reason for this..
thanks.
gain (gm) goes as W/L. Up to some point, front end gain
is the most significant thing you can play with for low-
overdrive differential amplifier speed.
