Morse Code using PIC18F252 ASM code
vins5
Newbie level 1
Lebanon
hey there,
i have my first microprocessor project at uni, and its about building a simple Morse Code using a PIC18F252 writing it in ASM
The main idea is the type a letter at the Hyperterminal and transmit it to an LED blinking light
for example:the letter A which is ( .-) the LED should blink once then 3 times in a row, so it would be like 10111 ( 1->the LED is on 0->its off)
so if anyone can help me with that , im finding a problem with using the timer to Blink the LED according to the letter written on the terminal
thank you.
You can use a Timer to create the dash and dot delays, but three software delays would also work.
Send Dash
Turn on Led
Delay Dash
Turn Off led
Standard Pause
Send Dot
etc
You cannot send the dash and dots out as you said, you need to send them out as a long Dash flash and standard off period and a short Dot flash
You should find help with Assembly on these sites
http://www.winpicprog.co.uk/pic_tutorial.htm
