more help for MCS48- need help in opcode for instrunction
satish.ghariya
Member level 1
Noida/Indore
more help for MCS48
Hi i also need help regarding opcode for instrunction , any usefu;l info...
I know no one is using this but i have to decode one hex..
Thanx in advance foe ur valuable suggession and help
s ghariya
Re: more help for MCS48
thanx dear friend.... i will load hex file to this and i will ack you after converting it to assembley.
Satish
Attached some information about the old 8048.
Maybe, you can use it.
Good luck!
Hi Dear...i am uplading hex file for my code ..i need to covert it to assembley programmm. This file is for old system and we need to understand the logic of this code . Bt we dont have assembley routine .. upload file has extention .txt ..change it to .Hex...Please send me converter if u have or convert it to assembley..
satish
more help for MCS48
Your apparently looking for a 8048 disassembler. You'll find several thousand links at google. But a low level disassembler listing is difficult to understand, particularly if you are not familiar to the 8048 programming model.
P.S.: See a DASM48 output of your hex code.
