relay voltage
Hi gang.
I built a monostable timer with a 555 ic. The timmer will energize 2 spdt 5v relays. The 2 relays are connected together in parallel so they can be used for reversing a motor polarity.
Here is some info on the timer and relay:
Timer-
100uf capacitor and 22k resistor to give a 2.4 sec time
Relays-
5v
59 ohm coil resistance
When I first tested the timer circuit, I used a 9v transistor battery for the timer power. I hooked up a volt meter to the output and when the timer was triggered, I got a voltage at the output of about 8v. Timer worked great.
When I connected the relays to the output, the timer worked like a switch. Meaning one trigger relay on, trigger again, relay off.
When I used 5v for the timer supply, the timer and relays worked perfectly.
Can someone tell me why at higher voltage, the relays latched in the energized state?
Was the higher voltage going to the relays creating too much of a load for the timer to time out?
I know that my circuit is working great at the proper relay voltage but would like to know why it did what it did at the higher voltage.
Sorry for the long post.
Thanks in advance.
Bill
