Note: This feature currently requires accessing the site using the built-in Safari browser.
i want to use wave port for monopole antenna. how can i do it??
anyone have design of monopole antenna?
I have absolutely no idea what you mean by a "wave port" ??
I cant find any reference to such a thing other than to do with harbours and shipping
car to explain a bit more ?
cheers
Dave
i want to make arm touch with ground in monopole.
u can see in attachment.. if u have any idea,share with me..
You need a small gap between the radiating arm and ground plane, like in reality. The lumped port is placed in this gap, with (+) connected to one end and (-) on the other end. This is your source, you drive the signal between the bottom end of the raidator and the ground plane.
Sorry, I use other solvers and don't have HFSS.
Wave port is useful where you have a plane with multiple conductors. For the monopole, use a lumped port between the radiator and the ground plane.
so what is a wave port ?
can u show me in jpg what u exactly want to tell me? i know we can put lump port between arm and ground
but it is possible to put port at the end of ground and make touch to arm and ground?
It is a technical term from EM simulation. Wave ports, as opposed to lumped ports, define an excitation on a finite area of the simulation boundary, and find the corresponding mode(s). This can be used for hollow waveguides or multi-conductor configurations. Unlike lumped ports, the reference impedance is not fixed, but instead is the impedance of that mode.
