Momentum Optimization Tutorial: ADS 2009
rshirodk
Hello,
I am using the Momentum tool of ADS 2009 which requires optimization. I was using ADS 2006 previously which allowed me to perform optimization in momentum itself, but I found that ADS 2009 Momentum does not support Optimization within it. The layout has to be exported to the Schematic window to perform the optimization.
My concern was mapping the optimization to the required dimension my layout file. What I mean by this is: I would want one of the dimension of my design to be optimized for better S11 response. I am not sure if according to the new procedure in ADS 2009 I am mapping correctly the dimension to be optimized to the parameter defined.
Some tutorials on Momentum Optimization should help.
Any kind of input would be appreciated.
Thanks
Rakesh.
benza246
Junior Member level 1
USA
so you can do the MOM optimization? Would you please give some other more detail example and Procedure?
Thanks
mouhsmah
How using ADS tocreated DGS
---------- Post added at 00:24 ---------- Previous post was at 00:23 ----------
How using ADS 2009 to created DGS
---------- Post added at 00:25 ---------- Previous post was at 00:24 ----------
DGS (deffected ground system)
