modifying parameter values of subckt running transient analysis hspice
shockingshockley
Member level 1
Member level 1
Hello,
I would like to modify the parameter GH from value of 1 to 35 when time is at 40ms (start time is 0ms; end time is 90ms) in the subckt:
.subckt MMR 880 483 762 tb=1 GH=1 jk=1
I would like to see the result in transient analysis. .alter I think is not the one to use because I only want to see 1 waveform. Could you help me?
Thanks in advance!
dick_freebird
Advanced Member level 7
USA
I have never seen a SPICE with ability to change netlist
on the fly. Consider using a switch element to do that
kind of thing.
FvM
Super Moderator
Staff member
Bochum, Germany
In other words, you want to supply a parameter with a time-variant value. I'm not sure if it's supported by HSPICE, you can try. If not, you need to redesign the subcircuit.
shockingshockley
Member level 1
Member level 1
thanks for the replies.
is it possible for example if the parameter instead is temperature?
