signal x : std_logic_vector ( 7 downto 0 ) ;
x ( 0 ) <= '1' ;
strange : process ( CLOCK , RESET ) is
begin
if RESET = '1' then
x ( 7 downto 1 ) <= ( others => '0' ) ;
elsif rising_edge ( CLOCK ) then
for index in 0 to 6 loop
x ( index + 1 ) <= x ( index ) ;
end loop ;
end if ;
end process strange ;
begin
if RESET = '1' then
x ( 7 downto 0 ) <= "00000001";
end loop ;
end if ;
I am not sure.....try this!
signal x : std_logic_vector ( 7 downto 0 ) := "0000001" ;
You may comment out this: x ( 0 ) <= '1' ;
x ( 0 ) <= some_entity_input ;
x ( 0 ) <= '1' ;
You wrote
x ( 0 ) <= '1' ;
x(0) must be '1' every time, not '0'.
I think it will be better:
Code:signal x : std_logic_vector ( 7 downto 0 ) ; strange : process ( CLOCK , RESET ) is begin if RESET = '1' then x ( 7 downto 0 ) <= "00000001"; elsif rising_edge ( CLOCK ) then for index in 0 to 6 loop x ( index + 1 ) <= x ( index ) ; end loop ; end if ; end process strange ;
And using for...loop constraction is bad idea. It works not the same like in C/C++ and others high-level languages.
x(7 downto 1) <= x(6 downto 0);
library ieee;
use ieee.std_logic_1164.all;
entity test is
port(
arst : in std_logic;
clk : in std_logic;
din : in std_logic;
dout : out std_logic_vector (7 downto 0)
end entity;
architecture arch of test is
begin
process(arst,clk)
begin
if arst = '1' then
dout <= (others=>'0');
elsif rising_edge (clk) then
dout <= din & din & din & din & din & din & din & din;
end if;
end process;
end arch;
If you try copy input bit in all bits of x:
Code:library ieee; use ieee.std_logic_1164.all; entity test is port( arst : in std_logic; clk : in std_logic; din : in std_logic; dout : out std_logic_vector (7 downto 0) ); end entity; architecture arch of test is begin process(arst,clk) begin if arst = '1' then dout <= (others=>'0'); elsif rising_edge (clk) then dout <= din & din & din & din & din & din & din & din; end if; end process; end arch;
It simulated corretly
library ieee;
entity test is
port(
clk : in std_logic;
din : in std_logic;
end entity;
begin
Code:process(arst,clk) begin if arst = '1' then dout <= (others=>'0'); elsif rising_edge (clk) then dout <= din & din & din & din & din & din & din & din; end if; end process; end arch; It simulated corretly[/QUOTE] This doesn't resemble to the original code. My logic synthesizes correctly. And if I put the x(0) <= '1' inside the process - I.E: [CODE]strange : process begin x ( 0 ) <= '1' ; if RESET = '1' then x ( 7 downto 1 ) <= ( others => '0' ) ; elsif rising_edge ( CLOCK ) then for index in 0 to 6 loop x ( index + 1 ) <= x ( index ) ; end loop ; end if ; end process strange ;
It also works.
I'm almost sure it's a bug.
As I said - Quartus synthesizes the circuit without any issues.So if not a bug? Did you tested your code in real FPGA device?
Code VHDL - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 Library IEEE ; Use IEEE.Std_logic_1164.all ; entity test is end test; architecture rtl of test is signal CLOCK : std_logic; signal RESET : std_logic; signal x : std_logic_vector ( 7 downto 0 ) ; signal y : std_logic_vector ( 7 downto 0 ) ; signal z : std_logic_vector ( 7 downto 0 ) ; begin -- original failed simulation with U on x(0) x (0) <= '1' ; original : process ( CLOCK , RESET ) is begin if RESET = '1' then x ( 7 downto 1 ) <= ( others => '0' ) ; elsif rising_edge ( CLOCK ) then for index in 0 to 6 loop x ( index + 1 ) <= x ( index ) ; end loop ; end if ; end process original ; -- working simulation y(0) is assigned '1' y (0) <= '1' ; no_for : process ( CLOCK , RESET ) is begin if RESET = '1' then y ( 7 downto 1 ) <= ( others => '0' ) ; elsif rising_edge ( CLOCK ) then y (7 downto 1) <= y (6 downto 0); end if ; end process no_for; -- also works as z(0) gets assigned '1', this is the way I would have coded this. embed_assign : process (CLOCK, RESET) is begin z (0) <= '1'; if RESET = '1' then z ( 7 downto 1 ) <= ( others => '0' ) ; elsif rising_edge ( CLOCK ) then for index in 0 to 6 loop z ( index + 1 ) <= z ( index ) ; end loop ; end if ; end process embed_assign; end rtl;
Are you saying it's the same with Verilog?...same process/always block...
Either way. Regarding the "not a bug" thing...I couldn't find any information about it. And if it's out of LRMYes, that is exactly what I mean, I've seen weird things happen when splitting up a vector and assigning parts of it in different places. Verilog though does keep you from using continuous assignments when you have the rest of the bus in a always block as the first uses the wire type and the always block uses reg. With the logic type you could get into the same trouble as VHDL.
Vivado's simulator also shows no warnings for this, that's why I suggested the behavior might be defined by the LRM assignment scheduling definition. One could easily assume that the behavior if not well defined in the LRM would result in different behaviors across vendor's tools, but considering both tools show the exact same behavior with the same condition seems to indicate that it might be the expected behavior, though I'll admit the synthesis tools do something entirely different (another good reason to avoid this type of coding).
