# Attempting stack trace sig 11
# Signal caught: signo [11]
# vsim_stacktrace.vstf written
# Current time Wed Nov 21 13:09:24 2007
# ModelSim Stack Trace
# Program = vsim
# Id = "6.1b"
# Version = "2005.09"
# Date = "Sep 8 2005"
# Platform = win32
# 0 0x0063ba35: '<unknown (@0x63ba35)>'
# 1 0x0063ba72: '<unknown (@0x63ba72)>'
# Corrupt Call Stack
** Fatal: (SIGSEGV) Bad pointer access. Closing vsimk.
** Fatal: vsimk is exiting with code 211.
(Exit codes are defined in the ModelSim messages appendix
of the ModelSim User's Manual.)
1. Go to start > Settings > Control Panel
2. Double-click on "Users and Passwords"
3. Select the user and click on "Properties" tab
4. Click on "Other" and select "Power User"
I was using a licensed version and it also crashed lots of times...to avoid all of this, I had to use an older version which didn't have all the recent optimizations of the newer version (which exited upon storage of generated results...!!!)
why dont you give a try With Expert edition of ALDEC probably u will get some solution
not remembering exactly but same kind of error was solved in that ....
