Open modelsim and look in the libraries section see if you have altera_mf along with work and the ieee libraries. If the libraries don't show up in modelsim along with the work library then they aren't compiled into a library or there isn't a line(s) in the .mpf or ini file specifying where the libraries are located (vmap) or worstcase they were incorrectly compiled into the work library.
Thanks very much for the replies.Yes I can see compiled altera_mf library along with work, ieee etc in modelsim but still I can't find the component during simulation. Thanks
Have you declared an scfifo component locally? if you have, this will override the on in the _components package and may cause it not to bind to the entity.
FIX: Dont have locally declared components for altera stuff.
