taskmn57
Newbie level 5
I am simulatin my VHDL code in modelsim through Xilinx ISE there are many cases that when I run simulation modelsim runs and stops at below stage!... I don't see what has caused this problem:
# vsim -lib work -voptargs=\"+acc\" -t 100ps work.SDI_Ftest
# Loading std.standard
# Loading ieee.std_logic_1164(body)
# Loading ieee.std_logic_arith(body)
# Loading ieee.std_logic_unsigned(body)
# Loading ieee.numeric_std(body)
# Loading work.sdi_ftest(behavior)#1
# Loading work.sdi_f_detector(behavioral)#1
# Loading work.pattern(behavioral)#1
it never goes on below messages and thus run> will not appear at all.
# .main_pane.wave.interior.cs.body.pw.wf
# .main_pane.structure.interior.cs.body.struct
# .main_pane.objects.interior.cs.body
run>
I appreciate any help if you have any idea.
Regards,
Hossein Moradi
run>
Regards,
Hossein Moradi
