Don Quijote
Newbie
Hello everyone,
I use Modelsim DE-64 2019.3.
I have a complex design with lots of "generate"-blocks in it. When I run code coverage and only include selected modules, every "generate"-block is analyzed even though none of the selected modules is inside the "generate"-block. This corrupts the total coverage (and other results of the analysis).
Long ago, there used to be a command for the modelsim.ini-file called "-nocovergenerate", but it doesn't exist anymore.
What can I do to get Modelsim to ignore the "generate"-blocks?
Thanks for you help!
