hwbill
Newbie level 1
I get different behavior depending on how I define a clock divider so I wrote some test code. I'm using modelsim-altera 10.0c. Here is the code.
always @(posedge clk or negedge reset_n)
if (~reset_n)
begin
aclk_div <= 0; // 2 bit counter
bclk_div <= 0; // 2 bit counter
end
else
begin
aclk_div <= aclk_div + 2'h1;
bclk_div++;
end
if (~reset_n)
acount <= 0; // 8 bit counter
else if (aclk_div == 2'h3)
acount <= acount + 8'h1;
if (~reset_n)
bcount <= 0; // 8 bit counter
else if (bclk_div == 2'h3)
bcount <= bcount + 8'h1;
I would expect the behavior of acount and bcount to be identical. However, acount transitions at the clock edge when aclk_div == 3 (which I think is correct) and bcount transitions on the clock edge when bclk_div ==2.
Any thoughts?
if (~reset_n)
begin
end
else
begin
bclk_div++;
end
if (~reset_n)
if (~reset_n)
Any thoughts?
