mobile control security system
chenoi
Junior Member level 2
pic sms
Hai, could anybody help me on how to built a device (pic) connected to handphone and pc where i can control input just by sending sms. i already search through internet and iam trying to built one. could anybody help me. i want to use PIC16F84A as the controller as iam doing alot of thing with this MCU and control by nokia 3310. may be somebody could provide me the step and all the hex file that i need to built one. i interested on this project but have lack of experience!
please give me a guide!
terka
sms pic
Hi chenoi
First, you must search by "pdu" or "sms" in this forum.
To start, nokia have a propietary protocolos, known by MBUS/FBUS. To comunicate your PIC to cell phone you have to use this protocol.
But, you can use another way. Using AT command, this ist work for each cell phone that support AT command.
This AT command are characters in 8 bits, which you can send from PIC to cell phone in serial mode. The phone receive this string sequence and run the instrucction to send the SMS to desired destination.
Cell phone send SMS in PDU and Text mode. no all cell phone suport text mode.
to test the operation sms mode:
at+cmgf? enter
0 => pdu mode
1 => text mode
To create a sms in pdu mode, you can use the "pduspy" software, which creates the pdu frame with "data information". This pdu is a string of ASCII character, and take it, insert it in the PIC , and send it to the phone, after send AT command
example: send mesagge in text mode using
AT+CMGf= 1 ==> set phone to text mode sms
AT+cmgs="+4594567890" , enter key ==> cell phone number destination of message
>Text to send + ctrl+z => to finish the text to send.
the phone answers with following:
+cmgs: 0 => 0 is the message reference , how much sms has been send by cell phone, it should be other numbers
Now, you must investigate the text or pdu mode of sms, and how create the code for PIC
sorry to all for my bad english
bye
chenoi
sms controller circuit diagram
thanks terka, but i need the device schematic (pic16f84) and the hex file where i can try to built one. what i have is a system with atiny and avr controller as iam not familliar with this. i hope i could have device that use pic 16f84 for this project.
bayramonur
Junior Member level 1
pic sms controller
:::::::::You find this subject from ::::::::::
this program was written in PICBASIC language.
terka
pic sms control
OK
you have to search in google for:
"nokia pin out" or "nokia cable schematic"
This for see the circuit to make, the input voltage for nokia phones is 2,7 volt. The pic send 5 volt for a logic 1. You can use a resistor in serie with a zener diode, and conect de input pin of nokia to cathode of zener diode to obtanin 2,7 volts. Idem for RX system.
view the attached circuit.
The 16F84´s software must have a rs232 protocol implemented in software.
http://www.winpicprog.co.uk/pic_tutorial7.htm
Bye
SAR
sms controller project
Some help for you here: **broken link removed**
Taro
Full Member level 2
pic sms project
I think this TOPIC may helpful
ilkeruzun
Newbie level 1
pic+sms
h**p://
chenoi
picsms
Thanks guyz..i think i have what i need here. :)
terka
pic fbus
HI
Here a good pdf file to learn to use AT command for r520m.
Enjoy
EnginerdUSA
Newbie level 1
nokia fbus pic
You can find some code samples at www.usbdeveloper.com.
They are using a Microchip to send SMS via an external mobile phone.
So, I think you can work further from there.
gidimiz
Advanced Member level 1
nokia 3310 sms controller
Im sorry to say but there is no why easy or a hex file to solve your problems. you will need to write some code on the PIC. you best way is this:
Buy a Data cable for you mobile phone, its much more easy then to build one. Be sure that the data cable can work with AT command, FBUS and MBUS are very hard to use and debug protocoles.
Then on the PIC write the code to receive and trasmit with your UART.
When the pic will load it sould program the phone to use TEXT mode and not PDU.
Then use the attached files that i send to read and delte the received SMS.
The easy way to turn things on and off is buy sending simple Text sms to the phone. for example, send 31 to turn output 3 on, and 30 to turn output 3 off.
The attached files will help you to understand the AT command structure, And the Original Nokia file will show you how to read the SMS.
Good luck.
hassan1980
Full Member level 4
sms con pic
In Siliconchip magazine there is a project for sms control using AVR micro, but you need to pay for the article
jojokatada
Full Member level 5
sms pic controller
hi it seem i also have similar problem on how access the phone and sending an SMS message i have problem in access the nokia phone and sending an AT command via an FBUS/MBUS
refer to my post sending an AT command to phone
glenjoy
Banned
Philippines
sms controller schematic
FBUS and MBUS cannot and will not understand AT Commands using an FBUS/MBUS cable alone.
jojokatada
Full Member level 5
pcb sms controller
hi gidimiz
i download the file you upload nokia 6210 using hyperterminal i try to use it but in my pc i can't find the nokia 6210 data cable at the connect using dropout in my pc i only see COM1 COM2 and TCP/IP.
my question is the cable you mention in your post that when buying the cable it come with the driver?
appreciate for reply
david753
Full Member level 1
control sms pic16f
Hi, Guys,
I am interested in this project.
I have a mobil phone, ACER G-530.
But, I cannot find its pinout.
Does anyone have answer?
APPRECIATED.
terka
fbus pic
david753 said:
Hi, Guys,
APPRECIATED.
FROM https://www.zfone.com/mobiles.php/phoneid/10245
I found that you G530 does not have a MODEM built in, perhaps it does not have a AT command set implemented.....sorry, you must buy a new cell phone
Bye
faroo28
sms control circuits
Check this site for SMS remote Control Function using Ericsson phone
    V
