gprs simulation channel
Hello,
Actually, it is a very complicated process to simulate the mobile channel but it is possible .. E-r-i-c-s-s-o-n has a software called GATE / MATE ( GPRS Application Test Environment for GPRS Data connections Simulation ) and ( MATE IP routing and simulation core for 3G network applications ) .. By the way, you can use some settings in GPRS simulation to simulate a data connection for normal GSM network ( by limiting the available time slots to one time slot per user and reserve that time slot for GPRS usage only ) .. This software enables you to simulate the following:
bit error rate
signal to noise ratio
number of background users
burst noise effect
but the problem is that the software is only for internal use ( but they also sell the service of simulatio for you ) .. so, you can go to the local branch in your country and ask them if they can help you to simulate your application ( you can use any application if you are only interested in old gsm network simulation ) ..
If you are interested, I have simulated in my local office a digital image transfer on GPRSand 3G networks and I have the results ..
regards
meshmesh
