MMC read problem help
faiflay
Member level 1
Member level 1
i build project that read data from the MMC but the main problem that the address of the first block to be read must be the first address of sector N*512 although the address in the write command it can be address of any byte
SO
i use pic16f877 in assembly lang and i successful to :
1- initializing the MMC
2- set block length as 32 byte
3- read and write from MMC but in only address N*512 (N=1,2,3,.......)
i access MMC without FAT system
i need to read from any address in MMC not only N*512 (N=1,2,3,.......)
i need to access any block in MMC
how can i do this?
