I'm stepping into a project that involves mixed language design (VHDL and Verilog).
Most of the files are *.V while some are *.VHD
How do I compile them to a single project ?
Suppose I have a verilog file named : "some_verilog_file.v" and in this file there's a module named: "some_verilog_module".
If I want to instantiate this module in a different VHD file - all I need to do is declare "some_module" as a component and instantiate it - as if "some_module" was a true VHDL written entity ?
--VHDL code
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
entity vhdl_top is
Port ( A : in STD_LOGIC;
B : in STD_LOGIC;
C : out STD_LOGIC);
end vhdl_top;
architecture Behavioral of vhdl_top is
component ver_cnt is
port(
a: in std_logic;
b: in std_logic;
c: out std_logic
end component;
begin
--instantiation
uut : ver_cnt port map(a => A, b => B, c => C);
end Behavioral;
//Verilog Code
module ver_cnt(
input a,
input b,
output c
assign c= a ^ b;
endmodule
