Mixed-Signal simulation using SpectreVerilog
mcjackson_hxw
Newbie level 3
PRC China
spectreverilog tutorial
I'm a beginner of spectreVerilog. Could you answer me a question, please?
In cadence, I want to simulate a digital circuit (digital filter) using spectreVerilog.
The verilog description contains many modules( I use Modelsim to write it).
But in cadence multi-module in a "functional" view is forbidden. How could I solve it?
A spectreVerilog tutorial is available, and I can email it to you if you need!
how to use spectreverilog
Usually I split the code and make a symbol for each sub-block and create a schematic view to connect all the blocks.
thus you can use that tool. This is just a workaround.
schematic to spectreverilog
You can use the verilogin command in Cadence and then you can build the functional view.
Yibin.
I agree with piao, as this is more organized to have each module in a file and represented by a block. It is a very powerful tool, as it is so easy to troubleshoot any error occurs. Try it !!
