Mircostrip antenna design. NEED HELP!
dong86
Newbie level 6
malaysia
Can You All please guide me how to build a microstrip antenna? It is better Steps by Step, cos i am quite weak or stupid !
1) How to decide the size of patch, substrate and feed?
2) what components should i prepare?
3) How to build the antenna
4) By using what software to test the antenna!
Thanks for your help!!!
there you have an excel doc in order to help you to decide about patch antenna size. It is in spanish.
Enric.
Hello
The size of the patch depends upon the frequency of operation. Hey, u can refer antennas by Balanis, u can find step by step procedure for designing patch antenna and for advance u can refer "microstrip antenna design handbook" -artech house
for simulation u can use IE3D or Ansoft hfss or Ansoft designer.
regards
Hi
Can we open a file made in HFSS v11 in Ansoft Designer sv2?
If yes, pl tell how because i am unable to do so.
THX
hi,
Did u ever figure out how to design your patch antenna step by step? If so, do you have some sort of document that can help me accomplish the same task?
Thank u
@ahsaan
as far as i know you cant open HFSS model in Ansoft Designer
regards
u can take this as help
CONFIGURATION FOR EDGE FEED
RT Duroid 5880
relative permittivity = 2.22
Fr=2.4 GHz
Substrate thickness h=0.795mm
Tan D (loss tangent) =0.004
Wave length (λ) =125mm
CALCULATED VALUES
Ltransformed=59.895mm
Wtransformed=48.2914mm
Zin = 289.80ohms
Effectve permitivity= 2.167
hi ,
please , i not so fluent in english
did anyone know about aluminium foil ?can that use to
patch microstrip antenna array... ?
how much value :
relative permitivity ?
substrate thickness
tan D
I will try to made microstrip from that medium for
patch antenna 2.1 Ghz
I only use 4nec2 ,... can i..
Thank u
can any one help me .....please
can u please give me the information about the circular micro strip antenna ,design and fabrication
also please post the formulae of circular microstrip antenna
no need to complex formulas for antenna design
investigate the program antennamagus (www.feko.info) :D
you can download the demo version
i am doing my circiculum project on circular microstrip antenna design and fabrication .....i need information about how to deisgn and fabricate the circular microstrip antenna
and i should write programming in 'c' to calculate the antenna parameters ...................
would u please post the information about this
hey i want to simulate broadband & Dual band circularly polarized antenna using ansoft HFSS software.
I need urs help in this regard
Thanks
For antenna S-parameters, radiation patterns and efficiencies, you can use EM-Core to simulate them.
Info. for download and antenna design can be found at
https://www.pedasoft.com/
hey u can go through the Ansoft hfss v11 software n its manual. it will be helpful for u
