minimum number calculation in the integers set
K.S.GANESH KUMAR
Newbie level 3
Newbie level 3
Tamilnadu
hi,
can anyone send VHDL code for calculating minimum.
example :v1=3,v2=4,v3=5,v4=1,v5=6,v6=8,v7=5,v8=10. the minimum no is 1.
i need VHDL code for this minimum calculation.
i have one solution using if then else concept.but i want to use loop or other method.am also try loop concept but the code has some error.
so anyone tell the code concept plz..
Thanks.
you would need to declare a type for an integer_array:
type integer_array is array(natural range <>) of integer;
from there you could write a function:
function min(x : integer_array) return integer;
You can use the for loop in the function body.
Also you can use loop in a process.
for this method you can add a variable to process and use a for loop to find the minimum.
Then assign it to a whatever you want
