Miller OTA Design - questions about Miller methodology
dtzounakos
Member level 3
Member level 3
Miller OTA Design
I uploaded af paper about Miller OTA based Gm/IDS Methdology!It's short and simple.
I understood everything except the concept of finding the Early Voltage VA3,VA4
through equation 1! From design specifications we know the overall gain Av(dB)> 80,
not Av1. How do we know and calculate Av1 dc gain? I would appreciate if someone
could spend a few minutes and answer my question!
Thanks!!
erikl
Super Moderator
Staff member
Advanced Member level 7
Germany
Re: Miller OTA Design
dtzounakos said:
... I understood everything except the concept of finding the Early Voltage VA3,VA4 through equation 1!
From design specifications we know the overall gain Av(dB)> 80, not Av1.
I think the statement
"considering the DC gain spec, L1 and VA1, the current mirror VA3 can be obtained through equation 1 → VA3 = VA4 = 10.2;"
is wrong: Like VA1 = VA2 (s. item above the a.m. statement), VA3 = VA4 = 10.2 is obtained from the gm/Id vs. VA curves (with L as parameter, s. item below the a.m. statement), not through equation 1 . Then, with all values introduced into this equation, Av1 can be calculated (Av1 ≈ 100 = 40dB), then similarily Av2 .
It's not the only error in this paper: M1-M2 is a PMOS differential pair, not an NMOS (p. 3), and L(M8 ) = 1 and not 1.5µm (p. 4).
HTH! erikl
dtzounakos
Member level 3
Member level 3
Thanks for interesting to this paper.
But i still can't uderstand how calculates VA3,VA4 without prior knowing the right
value of L3=L4! At first statement, we choose L1=L2=3um and we find value
VA1 and VA2 through plot VA=f(Gm/IDS)! At second statement, we don't know L3,L4
and VA3,VA4.In order to estimate one value of these variables, we must prior know
the other value!
Unless if we prior choose (arbitrary) Av1=40dB!
erikl
Super Moderator
Staff member
Germany
dtzounakos said:
... i still can't uderstand how calculates VA3,VA4 ...
No, it's not calculated, it's obtained from the gm/Id vs. VA curves (with L as parameter), s. my previous posting.
dtzounakos said:
... without prior knowing the right value of L3=L4!
gm/Id is already known. In the gm/Id vs. VA family of curves (L is the family parameter) a parallel line to the x-axis is drawn with the known ordinate value gm/Id. It meets the array of curves at several points which mean L-VA pairs. Now you can choose a convenient L-VA combination, e.g. 0.6µm - 10.2V for M3-M4 in this case, which will achieve a reasonable Av1 .
dtzounakos said:
At first statement, we choose L1=L2=3um and we find value VA1 and VA2 through plot VA=f(Gm/IDS)!
Yes; same method as mentioned above. The L-value is governed by considering the required GBW, as well as by noise & matching (means: offset) requirements. The chosen relatively high L=3µm value achieves an appropriately high VA1=VA2 value.
dtzounakos said:
At second statement, we don't know L3,L4 and VA3,VA4.
In order to estimate one value of these variables, we must prior know the other value!
That's true, but you can always choose between several L-VA pairs, s. above. Higher L-VA pair values result in larger gain & GBW, however need more real estate area.
That's another possibility. In this case, the VA value can be calculated, and the point of intersection between its value and the known Gm/IDS value on the VA=f(Gm/IDS) array of curves gives the L value.
Reactions: Fabien
    Fabien
dtzounakos
Member level 3
Member level 3
Thanks for reply. I understood the concept!
