* Function PlayMP3()
* Overview: Function runs mp3 example. Should be called frequently
* Input: Nothing
* Output: Nothing
void PlayMP3()
unsigned long i;
char str_file_size[22],str[22];
char buff_size[22];
//Init_FAT();
//MP3_Init();
current_file = FAT32_Open("sound.mp3", FILE_READ);
//Debug file status
IntToStr(current_file, str);
UART_Write_Text("File status Line 219: \n");
UART_Write_Text(str);
UART_Write(CR);
if (current_file >= 0 )
//TFT_Write_Text("3. File Opened", 90, 95);
FAT32_Size("sound.mp3", &file_size);
LongToStr(file_size, str);
UART_Write_Text("Sound.mp3 size at start Line 231:\n");
UART_Write(CR);
Delay_ms(500);
Total_Buffers = file_size / BUFFER_SIZE;
level = 0;
MP3_Set_Volume(level, level);
UART_Write_Text("3. File Opened\n");
while (file_size > BUFFER_SIZE)
//if(file_size > BUFFER_SIZE){ // while there is still data, send it to mp3 codec chip
//MP3_CS = 1;
//Mmc_Chip_Select = 0;
for (i=0; i<BUFFER_SIZE; i++)
Fat32_Read(current_file, mp3_buffer + i, BUFFER_SIZE);
UART_Write_Text("FAT32_Read Line 246!\n");
//Fat32_Read(current_fhandle, mp3_buffer,1);
//Mmc_Chip_Select = 1;
//MP3_CS = 0;
//MP3_CS = 1;
//BSYNC = 0;
//Delay_ms(1);
//UART_Write_Text("BSYNC = 0_Read Line 256!\n");
for (i = 0; i < BUFFER_SIZE / BYTES_2_WRITE; i++)
//for (i = 0; i < 32; i++)
MP3_SDI_Write_32(mp3_buffer + i*BYTES_2_WRITE);
//MP3_SDI_Write(mp3_buffer + i*BYTES_2_WRITE);
// UART_Write(mp3_buffer[i]);
// UART_Write_Text("Song loop >BUFFER_SIZE..\n");
file_size -= BUFFER_SIZE;
LED = 1;
UART_Write_Text("File size Line 286:\n");
UART_Write(CR);
Delay_us(10);
UART_Write_Text("file_size < BUFFER_SIZE will start, Line 272!\n");
while (file_size < BUFFER_SIZE)
//if(file_size < BUFFER_SIZE){ // finish playing file
Fat32_Read(current_file, mp3_buffer, file_size);
for (i = 0; i < file_size; i++){
MP3_SDI_Write(mp3_buffer[i]);
// UART_Write_Text("Song loop <BUFFER_SIZE..\n");
LED =0;
UART_Write_Text("file_size < BUFFER_SIZE has finished, Line 304!\n");
StopMP3_File();
else
UART_Write_Text("Failed opening file!\n");
