ayhampic
Member level 1
Hi ,
I've downloaded the MikroC pro for pic compiler 5.61, and I have a ICD2 Programmer , I want to use the BootLoader Capability to load my code the problem is :
1- Where can I find the .hex file for 18f4550 48Mhz ?
2- is it possible to use Serial BootLoader , How ?
3- if not how can i use the Usb BootLoader ?
4- Is it possible to debug Using BootLoader ? and how can i connect my icd2 programmer to the mikroc
the whole Problem That I need a complete Solution for (c++ compiler) and a BootLoader programming and debugging ?
any Suggestions would be appreciated .
thank all
thank all
