Microwave Oscillator Design
granix
Newbie level 1
frequency pulling microwave oscillator wiki
I am require the to design a microwave oscillator using ADS with specs below :
Microwave Oscillator Design specifications
Output frequency: 12GHz
Output Power: 5mW
Frequency Pushing factor <100 kHz/V
Frequency Pulling factor is less than 50 MHz peak-to-peak for a 1.5:1
Load impedance, Rl 50 Ohm
Anyone have any example or guideline to do it ? I had done numerous filters design but oscillators is my first.
I have some knowledge on oscillator but i found it kinda hard to apply to ADS.
Hello,
I suggest that you start with the oscillator design guide in ADS. It is a tutorial with step by step design procedure.
Feel free to ask more about it if you need more help.
Mohamed
Well, seems
means you need good regulator and output buffer.
So it more than a simple oscillator tutorial.
Have fun,
Hello,
I suggest u to go for oscillator basics first.Decide Topology hv calculations with u then u go for simulation.
eng_mbarko said:
Hello,
Mohamed
Hi, im new here. Where i found this??
thx.
Hello,
Mohamed
Please can anyone help out.
I am working on design of oscillator and need to make the transistor unstable, i.e
convert from common source(2 port)->common gate(3port) and to common gate(2port) to,i can only see the procedure i nedd the formula to do this
