Microwave/MMIC INTERVIEW Question
Puppet1
Advanced Member level 2
Assume a device can be represented by the transmission line network.
We measure with a network analyzer calibrated to 50 ohm reference impedance.
-------------------(line length = 15mm, Zo=30ohms)---------(load = ZL = ?)
S11-------------->
0.4(154 degrees) @ f=3GHz
(S11 looking into this network)
What is the complex load impedance at 3GHz if device under test consists of 15mm section of microstrip transmission line whose characteristic impedance and effective dielectric constant are 30ohms and 6.7 respectively, at frequency of interest.
A) assume microstrip is lossless
B) then assume loss factor 1dB/cm at 3GHz
Answers to this problem welcome !
Puppet1
no i am not offering a job.
people keep asking for interview questions, so i posted one.
if you answer it i will be impressed.
bhgaurav
Junior Member level 3
hey thanks for the question..keep posting more..it helps
useless!!! warning 2
--eirp
