Microstrip patch antenna. Need help
Salving
Member level 1
Please, anybody. help me. Give me any idea why increasing the height of the substrate gives better radiation efficiency.
chaitu_b99
Junior Member level 3
Hello,
Go through the book "Antenna Theory by Balanis", you can good idea of the radiation efficiency wrt height of substrate.
Salving
Member level 1
I've already read it twice) there is decreasing in efficiency with substrate increasing
chaitu_b99
You can increase the height to some extent...beyond one point the standing wave will appear, which will result in the decrease in the efficiency.
Salving
Member level 1
thanks) but i'm asking about different thing
due to the theory efficiency must come down with increasing the height, that is what in Balanis
V
volker_muehlhaus
Where did you find that?
Quote from the Balanis book:
"There are numerous substrates that can be used for the design of microstrip antennas,
and their dielectric constants are usually in the range of 2.2 ≤ Ir ≤ 12. The ones that
are most desirable for good antenna performance are thick substrates whose dielectric
constant is in the lower end of the range because they provide better efficiency, larger
bandwidth, loosely bound fields for radiation into space, but at the expense of larger
element size [38]"
Salving
Member level 1
That's what i found in Balanis, Antenna Theory - page 763, fig. 14.26
efficiency goes down
    V
streamlet
Full Member level 3
The influence of substrate height on the radiation efficiency should be described by two stages. Stage 1: When the height is small, dielectric loss (and maybe together with conductor loss) dominates. In this stage, the radiation efficiency increases with substrate height, since larger height leads to smaller dielectric loss and stronger radiation. Stage 2: When the height is large, surface-wave loss dominates and this loss increases with substrate height. Thus keeping increasing the substrate height cannot improve the radiation efficiency infinitely.
redcrtystalline
Junior Member level 1
hi increasing substrate height is equivalent to increasing permittivity and as you know it decrease radation
regards
