nikosnte
Junior Member level 3
Hello dear friends, i have two microstrip lines. One is straight with 18[mm] length, and the other one is constructed of many curved parts to be "bent" (second and fourth image attached). So, in order to achieve very small phase difference between these two lines i tuned the length of TLIN37 and TLIN40 to be 0.0965 [mm] and 0.6133 [mm] respectively. I simulated both lines in the schematic and i came with a very small phase difference for the whole frequency band as it can be seen (third image attached). Later i simulated the same lines in Momentum but the results were quite different (fifth image attached). I also got this warning
Now, i know that the results in Momentum may differ from the results in the schematic, but i don't know if i can trust these results because of this warning. My line width is 0.4557mm and i use dielecetric of constant 6.15. The frequencies are above 27 GHz. So the port width is bigger than λg/8 at some point and this is the reason i get this warning. Should i completely not trust my momentum results, or my schematic results? Thank you
