I have tried the 3 pole hairpin filter. Isn't that too small to fabricate?? its like 0.09 millimeter gap between the traces. I need a bit more easier one. Any other recommendations? And how can I get the actual PCB layout from Ansoft Designer?
There is a free tool from Nuhertz Filter solutions for Filter design...
& also a 30 days full version trial license also available it even as the dxf & sonnet export for Planar Transmissionline filters...
Re: Microstrip Bandpass Filter at 1 GHZ with 200MHZ Bandwidt
Hello there,
I am having trouble to get the print out of the layout from Advanced Design System(ADS).
I already have the design in ADS. To fabricate the interdigital filter, i need the negative image of the layout (copper in white colour and empty space in black colour).
Can anyone please help me.. Thank you so much in advance.
Tiyaj said:
Hello there,
You have to export your desing in Gerber format or GDSII format.You can do it easily by File-->Export--> Select your format and options then create your file .
Gerber file can be processed in a software to get the negative film ( for instance Gerber Tools.. etc.) or at the factory someone can get this image...
Thanks BigBoss, I have managed to export it into Gerber format. But, another problem is that I have tried many Gerber tools, I can only view and edit, but not printing in negative.. Can you recommend me any Gerber Software to do that...? Thank You very much.
