microstrip antenna result analysis in HFSS
ashinitj
Junior Member level 2
Chandigarh
dear all,
m wrking on micromachined microstrip patch antenna array in HFSS. i want to know how to get gain curves E-Plots and H-plots after simulation.
Do you want plots of the radiation pattern ?
yes i want plots of radiation patterns.....how to set values of theta and phi??
---------- Post added at 18:29 ---------- Previous post was at 18:28 ----------
use HFSS ver 11
m using ver 11
dear all,
Basic understanding of E-plane and H-plane radiation pattern. (There's no such as thing as E-plot and H-plot).
Simply E-plane and H-plane are always perpendicular to each other. 90 degrees onto each other.
Thus, to draw E-plane and H-plane.
Set one theta=0, and phi=all angles
or
Set one phi=0, theta = all angles.
You will see your H-plane will have circular and omnidirection patterns. Meaning it's perfect circles.
But E-plane is not uniform.
Remember, this radiation patterns are based on single frequency...so whatever your solution frequency is, that's the radiation pattern for the specific frequency.
This depends on the orientation of the antenna, so that's not a general result which will work in every case. Theta and phi have fixed references to the x, y and z axes. But depening on how you place the antenna, the E and H planes can be anywhere.
