I have RF application board / PCB with RF frequency range of 134MHz to 174MHz ,where RF module is used and the module is shielded .
But I want to shield the Microcontroller on the PCB too ,Can any one suggest a suitable metal material for shielding ?
Also problem is , I don't have any provision to solder the metal shield to the PCB so is there any other way where i can use metal film or foil or sheet for shielding without soldering it to board.
Normally the material of shielding is tinplate or nickel silver ,both easily to solder ,It's depend on your needs .
maybe you can visit http://www.jingyiprecision.com to know more about it .
