Ahamd Seirafi
Thanks again to all who reply.
You will find a attached file for the schematic which I designed.
The circuit is designed to read 8 PT100 sensors on PC using parallel port.
I need to use a micro controller instead and controlling 8 heaters concerning to the temperature sensors.
Can you help me find the suitable micro controller supporting 8 PWM outputs?
I deal with Atmel 89C52 and programming with C.
Best regards.
Best regards.
