Do u know actually why PonyProg not work with "USB2Serial"??????????????????????
is it the fault of language in which ponyprog is written???????????????????
---------- Post added at 13:37 ---------- Previous post was at 13:34 ----------
if the developer of PonyProg redeveloped it using JAVA or Visual C++2010....then it should sloved..........i think
No, ponyprog can work with usb to serial converts but not with ordinary converters.
At89c51cc03, at89s52
hi can u help me in keypad interfacing..i have 4x3 keypad and im using zilog specifically Z8f6421..thank you
i found this............
but in this the disadvantage is one connection from pc to uc for Programming,and another is for UART..
and philips chip it is only one ,which is UART,can do both programme&UART comm.
no Extra microcontroller needed for programming.........
just simple........
visit "https://docs.google.com/Doc?id=ddmkwx3z_21fb4jxzhc"
tnx rabin!
---------- Post added at 12:52 ---------- Previous post was at 12:33 ----------
tnx rabi..btw can u teach me how to know the scrolling... for example if i pressed 1 from the keypad and i have 4 seven segment the output would be 0001 and if i pressed 2 the would be 0012
thank you
u can do this by using BCD concept.
i.e:----(15)decimal=(0001 0101)bcd............
now just left shift 4bit..................
"when u press 1 then
int o;
o=0000 0000 0000 0001
when u press any next key say 3
o=o<<4;
o=o|input;"
and study BCD to Binary and vice versa conversion.
u may found BCD<->binary lib in internet
i think u want to make just like A calculator.??????????
then
i think ..........
1.check (PORTB|PORTC|PORTA|PORTD)==0?????????
if yes then ur disp=0;
2.if a key is pressed..i.e it is the 1st key.
3.if again a key pressed
<<4
|input
something like that but how the program goes?
