microcontroller input and output voltages
Antenna (^.^)
Member level 3
Hi everybody,
I am using ATtiny87 microcontroller, and I need 12 for I/O pins. The pins are digital ports. However I can't find anywhere in the datasheet to tell me what
exactly is the output voltage that is equivalent to 1 (on) and 0 (off). I also can't find the range of acceptable voltages input voltages the microcontroller
accepts (I found the operating voltage but i don't think that is the same thing)! :-?
Hello!
I would be surprised that it's not in the documentation, in "electrical characteristics".
You should find the maximal value of a 0 and the minimal value of a 1.
Dora.
Hi everybody,
what exactly is the output voltage that is equivalent to 1 (on) and 0 (off). I also can't find the range of acceptable voltages input voltages the microcontroller
see this,
refer this link http://www.atmel.com/Images/Atmel-8...ller-tinyAVR-ATtiny87-ATtiny167_datasheet.pdf
Page number for the complete table is 242
Above you see VOL and VOH,
Now look for VIL and VIH.
Klaus
