Microcontroller Initialization
yosabath
Newbie level 5
tblrdl
hi all,
Can anyone knows what happened when we switch ON the microcontroller before our main() function start? pls answer my question.
microcontroller initilization
The linker links in a 'start up' file. This sets up the stack pointer if you have one and initialises ram, globels and a few other things. It then calls 'main()'.
You can open and edit the start up file or just look at the code to see what it does. It is usually in the 'lib/src' directory.
Below is one of the Mplab_C30 start up files.
;; C Run-time startup module for dsPIC30 C compiler.
;; (c) Copyright 2002,2004,2007 Microchip Technology, All rights reserved
;; Primary version, with data initialization support.
;; The linker loads this version when the --data-init
;; option is selected.
;; See file crt1.s for the alternate version without
;; data initialization support.
;; Entry __reset takes control at device reset and
;; performs the following:
;;  1. initialize stack and stack limit register
;;  2. initialize PSV window if __const_length > 0
;;  3. process the data initialization template
;;  4. call the user's _main entry point
;; Assigned to section .init, which may be allocated
;; at a specific address in linker scripts.
;; Supports the zero-parameter form of main() by default.
;; If the symbol __ARGV is defined, supports the two-parameter
;; form of main().
;; Un-comment the following line to define symbol __ARGV:
;;      .equiv __ARGV,1
        .equ __30F2010, 1
        .include "p30f2010.inc"
        .section .init,code
        .global __resetPRI
        .ifdef __C30ELF
        .type   __resetPRI,@function
        .endif
__resetPRI:
        .weak   __reset
        .ifdef __C30ELF
        .type   __reset,@function
        .endif
__reset:
;; Initialize stack, PSV, and data
;; registers used:  w0
;; Inputs (defined by user or linker):
;;  __SP_init
;;  __SPLIM_init
;; Outputs:
;;  (does not return - resets the processor)
;; Calls:
;;  __psv_init
;;  __data_init
;;  _main or __main
        mov      #__SP_init,w15    ; initialize w15
        mov      #__SPLIM_init,w0  ;
        mov      w0,_SPLIM         ; initialize SPLIM
        nop                        ; wait 1 cycle
        rcall    __psv_init        ; initialize PSV
        rcall    __data_init       ; initialize data
                                   ;  clears w0, so ARGC = 0
        .ifdef __ARGV
          rcall  __main            ; call two-parameter main() setup
        .else
          call  _main              ; call user's main()
        .endif
        .pword 0xDA4000            ; halt the simulator
        reset                      ; reset the processor
        .weak __psv_init
__psv_init:
;; Initialize PSV window if _constlen > 0
;; Registers used:  w0
;; Inputs (defined by linker):
;;  __const_length
;;  __const_psvpage
;; Outputs:
;;  (none)
        bclr     _CORCON,#PSV        ; disable PSV (default)
        mov      #__const_length,w0  ;
        cp0      w0                  ; test length of constants
        bra      z,1f                ; br if zero
        mov      #__const_psvpage,w0 ;
        mov      w0,_PSVPAG          ; PSVPAG = psvpage(constants)
        bset     _CORCON,#PSV        ; enable PSV
1:      return                       ;  and exit
        .weak __data_init
__data_init:
;; Process data init template
;; The template is null-terminated, with records
;; in the following format:
;; struct data_record {
;;  char *dst;        /* destination address  */
;;  int  len;         /* length in bytes      */
;;  int  format;      /* format code          */
;;  char dat[0];      /* variable length data */
;; Registers used:  w0 w1 w2 w3 w4 w5
;;  __dinit_tbloffset
;;  __dinit_tblpage
;; Outputs:
;;  (none)
;; Calls:
;;  __memcpypd3
        .equiv   FMT_CLEAR,0    ;  format codes
        .equiv   FMT_COPY2,1    ;
        .equiv   FMT_COPY3,2    ;
        mov      #__dinit_tbloffset,w0 ; w0,w1 = template
        mov      #__dinit_tblpage,w1   ;
        bra      4f                    ; br to continue
1:      add      w0,#2,w0       ; template+=2
        addc     w1,#0,w1       ;
        mov      w1,_TBLPAG     ; TBLPAG = tblpage(template)
        tblrdl.w [w0],w3        ; w3 = len
        addc     w1,#0,w1       ;
        tblrdl.w [w0],w5        ; w5 = format
        addc     w1,#0,w1       ;
        clr      w4             ; upper = FALSE (default)
        cp       w5,#FMT_CLEAR  ; test format
        bra      nz,2f          ; br if not FMT_CLEAR
        ;; FMT_CLEAR - clear destination memory
        dec      w3,w3          ; decrement & test len
        bra      n,4f           ; br if negative
        repeat   w3             ;
        clr.b    [w2++]         ; clear memory
        ;; FMT_COPY2, FMT_COPY3 - copy bytes
2:      cp       w5,#FMT_COPY2  ; test format
        bra      z,3f           ; br if FMT_COPY2
        setm     w4             ; upper = TRUE
3:      rcall    __memcpypd3    ; copy 2 or 3 bytes
4:      mov      w1,_TBLPAG     ; TBLPAG = tblpage(template)
        tblrdl.w [w0],w2        ; w2 = next dst
        cp0      w2             ;
        bra      nz,1b          ; loop on non-zero dst
        retlw    #0,w0          ; exit (clears ARGC also)
__memcpypd3:
;; Copy data from program memory to data memory
;; Inputs:
;;  w0,w1 = source address   (24 bits)
;;  w2 = destination address (16 bits)
;;  w3 = number of bytes (even or odd)
;;  w4 = upper byte flag   (0 = false)
;; Outputs:
;;  w0,w1 = next source address (24 bits)
1:      mov      w1,_TBLPAG     ; TBLPAG = tblpage(src)
        mov      w0,w5          ; w5 =   tbloffset(src)
        add      w0,#2,w0       ; src+=2
        addc     w1,#0,w1       ;
        tblrdl.b [w5++],[w2++]  ; dst++ = lo byte
        dec      w3,w3          ; num--
        bra      z,2f           ; br if done
        tblrdl.b [w5--],[w2++]  ; dst++ = hi byte
        dec      w3,w3          ; num--
        cp0      w4             ; test upper flag
        bra      z,1b           ; br if false
        tblrdh.b [w5],[w2++]    ; dst++ = upper byte
        dec      w3,w3          ; num--
        bra      nz,1b          ; br if not done
2:      return                  ; exit
        .ifdef __ARGV
__main:
;; Initialize a stack frame to support
;;   the two-parameter form of main()
;; Inputs:
;;  (none)
;; Outputs:
;;  (none)
;; Calls:
;;  _main
        lnk      #6             ; construct frame
        mov      #0,w0          ; store a null terminator
        mov.b    w0,[w15-6]     ;  for program name
        sub      w15,#6,w1
        mov      w1,[w15-4]     ; argv[0] = &pgmname
        mov      w0,[w15-2]     ; argv[1] = 0
        mov      #1,w0          ; w0 = argc
        sub      w15,#4,w1      ; w1 = &argv
        call    _main           ; call the user's main()
        ulnk                    ; destroy frame
        return                  ;  and exit
        .endif
        .end
initialization microcontroller
When you switch on the microcontroller, all of the microcontroller's will go to default setting, and then PC(program counter) will go to address #000000h to read the program, notice that interrupt vector table for reset is the same address(#000000h). So if you trigger the reset button, the PC will be go to address #000000h.
When we write startup program, the startup program will initialize our setting(processor setting,pll etc).After initialize is done, it will jump to your main program.
Sometimes it depends on your microcontrollers, but i think most of the microcontrollers will do this.
Correct me if i'm wrong and Happy Learning.
