[PIC] microcontroller copy
balu76
Newbie level 2
hello to all...
sir, I have SM8952AC25P ics two no.s one is good and other is defective.I want to copy programme file of good ic to empty ic. on ic sticker is there as A1-03v1.1 . I want programmed ic SM8952AC25P for use to our device.please give details in what way I can get programmed ic
[Moved]Programmed microcontrollers
Sir, programmed microcontroller ics are any where available in the market or programmed file(HEX file) can I get anywhere .
Re: [Moved]Programmed microcontrollers
most of proprietary chips would be code locked.
I dont expect that you could copy and reprogram.
P{erhaps the only way is to correspond to company who supplied the equipment, pay and get a pre programmed chip claiming serial # of faULTY EQUIPMENTWITH MAKE AND MODEL.
May be there is a chance that you could get code for the controller. But you need to serach with the correct application in GOOGLE. But getting HEX file will tough I guess
