I assume that "IC" in your post means master (microcontroller) ..The high-speed mode (3.4Mbps) is normally found only on LCD display, high bit count ADC or high capacity EEPROM devices due to the need to transfer large amount of data. Most maintenance and control applications, the typical reason to use the I²C-bus, continue to operate at 100 kbps.
