technochrat
Newbie level 6
Hello all,
I am using a spartan 3A starter kit.I am trying to implement a simple DDR2 memory test system.
In my linker script i have configured the Code and Data memory,stack and heap to be located on the
LMB or blockram.The size of blockram is 8k,which,by my understanding is the maximum i can have in this spartan device.
I configured a stack and haep size of 1Kb each.With this I am not able to implement the whole functionality i needThe compiler shows an error indicating that the heap is full.
If i increase the heap size to 2kb then the compiler tells that there is an overlap of stack and heap memory range.
I did not want to use the DDR2 memory for this because i needed to test the whole memory range in my software.Suppose I use the DDR for the heap and stack I would like to know where this will be located,so that I can skip this memory range in my test algorithm.How will i do this?
And what will be the effect on performance if the stack and heap are located on the DDR?
any help will be appreciated.....
