Hello all,
I have had an about complex project using Microblaze and so, Implemented in a v6-130t and ٍnow the employer asked me to displace it to v6-240t.
what I have done to do this migration is regenerateing all the componnets such as IPs for new device.
the problem is that in new project I can not program the fpga and debug the MBLAZE code via SDK as I could. and the elf file is now disapeared! how ever I build the code again and it does not generate new error.
should I design and build new Microblaze core?:bang:
Porting a design between parts in the sme family (Virtex 6) only requires that you change rhe part number and the ucf/xdc constraints to match the new pins and locations. If the parts selected have compatible pinouts and you didn't use a pin that was not part of the common pins, then you probably wouldn't even have to modify the ucf/xdc file.
the target device and previous one are compatible. but especially the MBLAZE does not work,yet. however it seems the rtl codes work with no problem.
(regenerating IPs as I said means they just upgraded by software without any changes from me.)
