Meyer probability 3.37 problem question
snaider
Member level 5
meyer probability
Any one has solved the 3.37 problem of the meyer probability and application, it says like this :
3.37 you have n baskets, each one has w white balls and b black balls, if you take out a ball in the firts basket and put in the second basket, and take out a ball of the second basket and put in the third basket, and so on until the n basket. What is the probability of take out a white ball in the n basket, if in the first basket you take out a white ball.
Hi snaider!
Following is the solution.
Let P[k] = Probability of taking a white ball from k-th basket
So, 1 - P[k] = Probability of taking no white ball from k-th basket
So,
P[k] = P{a white ball taken from (k-1)-th basket AND then a white ball taken from k-th basket} OR P{no white ball taken from (k-1)-th basket AND then a white ball taken from k-th basket}
So,
P[k] = (P{a white ball taken from (k-1)-th basket}*P'{white}) + (P{no white ball taken from (k-1)-th basket}*P"{white})
So,
P[k] = P[k-1]* {(w+1)/(w+1+b)} + (1 - P[k-1])*{w/(w+b+1)}
P[k] = (w + P[k-1])/(w+b+1), after simplification.
And, P[1] = (w)/(w+b).
So, P[2] = {w + (w)/(w+b)}/(w+b+1)
= (w)/(w+b)
and so on ...
So, P[n] = (w)/(w+b). : ANSWER.
The result according to the book is :
P(n)=[w/(w+b)]+[b/[(w+b)*(w+b+1)**n-1]]
** exponent
In the result you give, you did not realize that you put a extra ball in each basket, so the total balls are w+b+1, and also that this is conditional probability.
