Methods to to effective broadband matching for amplifier
sze wen
Member level 2
Member level 2
I have done load pull simulations and found different Zopt for the 2GHz and 3 GHz respectively.
The Zopt will give me the maximum power transfer at the load side at different frequency. Hence needs 2 different matching network it seems to me.
Is T or Pi network good enough for broadband matching 2 GHz to 3 GHz?
How do we ensure that the output power and efficiency are still good enough?
Two different topics: 1) bandpass filters and 2) impedance matching...
It becomes difficult to combine both purposes into one filter. Furthermore input resistance might be unknown and unseen coming from your preceding circuitry.
We have the formula that tells what center frequency is produced by a given LC combination. LC ratio makes a difference in rolloff curve. To keep things simple I'm creating a basic simulation. Two LC configurations create bandpass. 47 Ω at both input and output.
This is merely an example. It's not likely to be optimum for your purposes.
Any expert in this forum?
For this wide bandwidth, theoretically a 3 pole Pi LC network should do the job, but 5 pole Pi network would be much better.
Any technique that could be used to improve the bandwidth after matching is variable matching etc?
The question can't be well discussed without knowing amplifier impedance characteristic. If you want to match a moderately varying impedance without distinct resonances to constant load impedance (e.g. 50 ohms), a LC network should work. Real source and load impedance components help to avoid new resonances introduced by the network. Starting with a useful network topology, the solution can be found by numerical optimization methods. Required network complexity depends on wanted matching performance.
If source impedance has already distinct resonances, it's usually not possible to cancel it by a lossless network.
Let's say the impedance seen by the power amplifier is 8. How do I transform them to 50 ohm?
The goal of impedance matching is to preserve power transfer (Watts=V x A). Therefore raw math says that when you have any amount of Watts through 8 Ω, you can convey identical power (theoretically) through 50 Ω...by multiplying V x 6.25 ... and reduction of current to 16%.
In addition to transformers as one method...
With sine waves you can achieve this by assembling one or more networks of inductors and capacitors, in correct values custom designed to perform with a particular frequency or range of frequencies.
For wideband, most simply by a transformer.
How to do it in Cadence.
--- Updated ---
Should we look at efficiency + output power instead of maximum power transfer.
Example clarifying which is which...
Cheap transistor radio running on 9V battery, with class A amplifier providing audio signal which is a few volts amplitude at tiny current. In this form iit would fall flat if directly connected to 8Ω speaker. It's a mismatch of impedance.
Now install an audio transformer in the collector leg. Step down volts. Step up current. As a side benefit it eliminates the DC component and instead provides AC to the speaker. Impedance is matched. Power level is preserved (Watts=V * A). Yet now signal is in a form such that speaker receives enough current to drive it efficiently.
is it recommended to use PI network
Perhaps two or more networks, and maybe one or more of another type also. Your operating frequencies are in a range that requires particular know-how. Fast-responding components. They may need to be arranged to avoid certain hurdles.
And chosen for compatibility with your previous stage or amplifier.
I notice my output power dropped from 30dBm to 21 dBm after the output matching network. Is it because the input network is not designed yet? The input that I have is 50 ohm resistor only.
Probably one or more of the following is true:
1. The Zopt you calculated is wrong
2. The output impedance matching network is incorrectly designed, and it not presenting Zopt to the PA output
3. The PA has poor reverse isolation (S12), and the output match is affecting the input match significantly.
How to design the output impedance matching given that we know there are parasitics cap?
LaTeX Commands Quick-Menu:
