rockycheng
Member level 5
Hello guys,
When I design a drive circuit, I found the wires carrying the pulse signals are quite long and go through some analog blocks. I'm trying to find some method to reduce the potential interference. I have 2 now:
1. Use shielding. But I don't like this method very much, since I worry that the noise may couple to the shielding wires close to it and thus contaminate the clean ground.
2. Add a parallel wire close to it that carries inverse pulse. Since the added wire has almost equal parasitic capacitance, it may counteract the noise injection of the original one. But I'm not sure if it has real effect, I hope someone would give suggestions to this method. Thanks a lot!!
