qqpost
Member level 1
Hi everyone,
Have you ever met HFSS problem like this?
"Mesh refinement is too deep. MDM mesher will make huge mesh for this model. Suggested solutions: (1). Remove the very small objects (2). Specify defeature length to certain objects "
I check the model. There are no small objects.
I also try another model, which can be successfully run. While when I change the length of one component from 60um to 70um, it couldn't.
It is so tricky that I cannot understand how to solve this mesh problem.
Is there any one has some suggestion? Thank you!
