Khurram1965
Hello all
Here are two vhdl codes (code-1 and code-2) both are separately work correctly, I wish to merge both codes please help for this.
code-1
code-2
bcd to 7 segment driver
code-1
Code VHDL - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 --4 BIT BINARY COUNTER library ieee ; use ieee.std_logic_1164.all; use ieee.std_logic_unsigned.all; entity counter is port( clk: in std_logic; reset: in std_logic; enable: in std_logic; count: out std_logic_vector(3 downto 0) ); end counter; architecture behav of counter is signal pre_count: std_logic_vector(3 downto 0); begin process(clk, enable, reset) begin if reset = '1' then pre_count <= "0000"; elsif (clk='1' and clk'event) then if enable = '1' then pre_count <= pre_count + "1"; end if; end if; end process; count <= pre_count; end behav;
code-2
Code VHDL - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_ARITH.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; entity test is port ( clk : in std_logic; bcd : in std_logic_vector(3 downto 0); --BCD input segment7 : out std_logic_vector(6 downto 0) -- 7 bit decoded output. ); end test; --'a' corresponds to MSB of segment7 and g corresponds to LSB of segment7. architecture Behavioral of test is begin process (clk,bcd) BEGIN if (clk'event and clk='1') then case bcd is when "0000"=> segment7 <="0000001"; -- '0' when "0001"=> segment7 <="1001111"; -- '1' when "0010"=> segment7 <="0010010"; -- '2' when "0011"=> segment7 <="0000110"; -- '3' when "0100"=> segment7 <="1001100"; -- '4' when "0101"=> segment7 <="0100100"; -- '5' when "0110"=> segment7 <="0100000"; -- '6' when "0111"=> segment7 <="0001111"; -- '7' when "1000"=> segment7 <="0000000"; -- '8' when "1001"=> segment7 <="0000100"; -- '9' --nothing is displayed when a number more than 9 is given as input. when others=> segment7 <="1111111"; end case; end if; end process; end Behavioral;
