My friend U got some steps backwords:
First do
./autogen.sh
./configure
make
su
******(your pass)
make install
ldconfig
A few players need xine so yast won't let you uninstall the original package if U don't hava a new rpm, this is not good.
First clean the package you installed!
if you didn't delite the folder where U compiled it go there and do:
su
make uninstall
ldconfig
now open yast2 and check for package problems, for example missing files yast shuld detect them and reinstall the apropriate packages.
Now copy all of the files U downloaded from packman's site to a dir in your home. Start in to kde go to the dir you copyed the files and with right clicking on xine-lib chose something simular to install package with yast. Yast will check the deppendencies and if they're satisfies by files in the current dir it will install fine.
If you can't install it like this start kpackage and with drag and drop drop all these rpm's in the kpackages window.
And again if you can't install it like this go to the dir where you untarred the sources and do:
./autogen.sh
./configure --prefix=/usr
make
su
checkinstall
Did U notice the difference? checkinstall is an app that makes rpm's from build binaries (install checkinstall from yast first, it's a console application wich requires root priveligies to run
) if all went well go to /usr/src/packages/RPMs/i386 (or i586 or amd depending on your hardware) and find the xine package you built. Now install this package with yast or kpackage and replace the egzisting packages, things shuld be fine now I home
