mtwieg
Advanced Member level 6
- Joined
- Jan 20, 2011
- Messages
- 3,907
- Helped
- 1,311
- Reputation
- 2,628
- Reaction score
- 1,435
- Trophy points
- 1,393
- Activity points
- 30,017
For my research I often have to compare the performance of different RF networks in a signal chain (for example, a LNA connected between an antenna and a mixer). Normally I have each stage as a separate PCB with BNC or SMC connectors, so I can manually arrange things how I want. But the problem with this is that the measurements are actually sensitive to the routing of cables and the position of the components, so manhandling the cables and connectors always disturbs things. I'd much rather have good RF switches to select the DUT without having to move anything. High isolation and very low loss (like >60dB and <0.3dB at 100MHz, respectively. Power level is very low, typically 10dBm max) are important, so mechanical switches would be ideal. The issue is that this has to be done in a powerful magnetic field, so no magnetic components are allowed, which seems to rule out all the mechanical switches I've seen, which all rely on relays or passive magnetism to work well.
So does anyone know of any good off the shelf nonmagnetic mechanical RF switches? Or how to DIY one? Even just a simple SPDT would be a great help.
