bababui
Junior Member level 3
Slew Rate
Hello,
I am trying to check the slew rate of my two stage differential input and single output amplifier. And I just want to make sure I'm seting up the test correctly.
I connected the opamp in unity gain configuration ( shorted negative input to output), and connected V common mode to the positive terminal. Now, do I just apply a square wave to the negative input? I'm a bit confused about that because it's also shorted to the output.
Hello,
