danilocunha
Newbie level 3
Hello, I´m not sure this is the right place for this post. But I believe it is.
I need to measure the attenuation of a filter (low pass) along the frequency (0 to 100KHz). I´m trying to do that with a FFT Analyzer from Stanford model SR770 to measure the frequency response o my circuit.
This analyzer has an source output and two inputs. I connected the source output to the input of my circuit and the output of my circuit to one of the inputs of the analyzer. And then I configured the source output to be a Chirp source. As I understood, the chirp source is equivalent to several senoids (or should I say sine?), one for each frequency bin. I setted the amplitude of the chirp output to be 1000mV.
So, if I´m not wrong, the measurement I´m doing in the output of my circuit is the gain of my filter. Right? And since what I want is the attenuation, I should invert this values (Att = 1/Gain). Right?
Another concern is related to impedance matching. The SR770 has an output impedance described in the specs as < 5 ohms. Should I include a 5 ohms resistor after my circuit? So it would have the same impedance in both sides.
Thanks. Any help and suggestions are welcome.
