Dec 11, 2006 #1 R rascabuche Member level 3 Joined Jan 29, 2006 Messages 54 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,286 Activity points 1,607 817b optocoupler can someone tell me how to measure an optocoupler with my DMM to see if its good or bad. i have an optocoupler with 4 pins # l0514the nomber below 817b. thanks for assistance Ras
Dec 11, 2006 #2 VSMVDD Banned Joined Jun 12, 2005 Messages 643 Helped 92 Reputation 184 Reaction score 34 Trophy points 1,308 Location scotland uk Activity points 0 optocoupler tester pins 1/2 are a diode so use a dmm set to diode range pin 3/4 are a transistor so you can use a transistor tester or dmm again in diode test however if its short here its gone if its open its usualy ok the only real way is to build a circuit on a breadboard etc and plug it in and pulse pin 1/2 with 5v ttl using a 220R current limiter resistor you can use an led on pin 3/4 and +5v a pullup and load resistor {1k is ok} here is a picture of a type of method to use
